Hi!
I made calculation of my scheme.
But it looks like only dead load was calculated.
Results from all other loads (vertical and horizontal) give me zero values of forces, displacements and deflections.
What could be the reason?
With kind regards,
me
Check whether these cases are not set as auxiliary.
Additional check:
Press Normalize button and \ or change scale
Fx scele : 500 or 100 and find the biggest value -> member
Deformation :change scale -> find the place on structure where it is
I've found reason - model generation was swithed off.
After I switch it on it works good.
Anyway, thanx for reply.
