Hi all.
I want load wind to centren of geometry of slap.
please toturial me seach centren of geometry of slap
I is attachment
please convert *.doc* to *.rar*.
Thanks support
Solved by Rafal.Gaweda. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
I do not understand
Take a look:
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-890C3B44-F7EE-4BB1-8C39-19F445B5B94E.htm
Thanks.
So center of mass slab = F - Coordinates of the center of gravity of story slab.
But i want find center of geometry slab ???????????????????
Please .
You could save out the particular slab as a seperate file, then check centre of mass for that object?
Or save as a seperate file then check the calculation report.
It's under Analysis-------->calculation report
What are the values of Ix, Iy, Iz? (kg*m2???)
These are mass moments if inertia about X, Y and Z axes.
Thanks.
Is there any way to RSA calculate the equivalent inertia of the structure?
