Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Load Takedown
3 REPLIES 3
jonpople
605 Views, 3 Replies
Load Takedown
I am using Robot to perform a load takedown and comparing it to a simple load takedown performed by hand based on the area of floor supported by each column/wall. I have noticed that Robot produces considerably different results. How does Robot calculate the load down the the supports? I guess that Robot takes relative stiffness of columns and walls into account with this calculation.
Jon
3 REPLIES 3
Rafal.Gaweda
in reply to: jonpople
Load Takedown in Robot? Are you sure?
Rafal Gaweda
jonpople
in reply to: Rafal.Gaweda
Surely the reactions produced at the supports after an analysis is perfomed should be similar to the reactions created by doing a load takedown by hand?
Rafal.Gaweda
Rafal Gaweda
