Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Load takedown
6 REPLIES 6
gustavo_c_vasconcellos
695 Views, 6 Replies
Load takedown
Is it possible to include the loads in Revit, do the combinations in Robot, update the Revit model and then run the load takedown extension?
Basically what I would like to do is use the automatic combination in Robot, but still use the Revit's extension.
Gustavo
6 REPLIES 6
in reply to: gustavo_c_vasconcellos
In my experience the loads / combos created in Robot won't go back through the vortex.......................:(
anyway, Revit just uses the trapezoidal method that you can set in Robot anyway.  Better to do it in Robot or export to CBS...
Tony
Rafal.Gaweda
Rafal Gaweda
Rafal.Gaweda
Loads and combinations created \ added in Robot are not imported (I mean non visible) in RST. But they are not lost. If you export this model once again to Robot you will still have them in Robot.
So if they are not visible in RST they can not be exported to Extension
Rafal Gaweda
Tony and Rafa,
as I have to send the foundation loads to another company to do the deep foundantion, I was trying to use the load take down extension due to live load reduction (Robot doesn't do it, am I right?) and to speed the documentation process.
Does CBS do live load reduction?
Gustavo
No, only in Load Takedown Extension.
Rafal Gaweda
in reply to: Rafal.Gaweda
Is there a way, to make the load takedown extension used in RST available in Robot ? It seems that he live load reduction factor works only for Eurocode 0 and ASCE, am I right ? Could we me make the extension create for RST available in Robot by the ''gestionnaire de modules complémentaires'' window as illustrated in the attached capture screen.
thank's for quick answer
Patrick
