Please help to fix this kind of problem:
In the Member calculation (column) mode i set needed settings for load cases factors.
But when i start applying those loads cases on the column - it shows different factors.
Please see attached pictures.
For example i need to set COMB DLx1.265, enstead of that Robot does DLx1.35. o_O
Victor
Solved by Rafal.Gaweda. Go to Solution.
The RC codes are linked with regulation files.
In this case it can be like that:
In case of importing such element from FEM model to RC module we recommend to generate manual combinations from code combinations in model and while importing to select Manual Combinations.
-Finnish annex EC-2.
-Its linked alright, but im interested in safety factors which are stored under CC2 in screen pictures.
-Im not importing column from FEM model. I started it on Member design mode from the start.
Like i said, i need to modify CC3 (structure class) safety factors but in calculations its still forcing into CC2 factors for dead load- 1.35
Thanks!
Victor
As I said this code is linked with CC2 regulation file.
Modify CC2 file.
That was the problem.
I modified CC2 file but it still was forcing to the wrong factor.
Apparantly it was some sort of bag on my work station coz when i tried to modify it on home laptop -it worked just fine.
Thanks for quick replies!
Check \ modify this file:
"c:\Users\user_login\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\CfgUsr\EC-SFS-C2.RGL"
or similar path.
If this file does not exist copy it there.
