Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Load of wall impact to slab ( But not Beam )
3 REPLIES 3
duchoabn
594 Views, 3 Replies
Hi all
I have a probelm with load of wall impact to slab (no chock beam) ---> wall no have beam below
pl see picture
thanks all
3 REPLIES 3
Artur.Kosakowski
in reply to: duchoabn
If you model both the wall and the slab as meshed panels the load will be transferred via their common nodes. You can also apply linear load on the slab instead of modeling the wall.
Artur Kosakowski
duchoabn
in reply to: Artur.Kosakowski
HI thanks Artur
My wall in model are curtain wall???--> I calculate load of wall on excel --> then add in robot???
How to guide to me define Lintel in robot?( Lintel in wall concrete)
pl see picture
Thanks Artur
Artur.Kosakowski
Define a dummy (with small cross section or  E value) beam under the wall so that its self weight is applied to a slab via this beam.
Personally I would define it as a beam when its height is relatively small and as a panel when not.
Artur Kosakowski
