I'm struggling to understand why I'm getting the warning 'load has not been distributed correctly - no objects or elements carrying load overlap', please see screenshot below:
The central panel is a cladding panel and load is being distributed as I'd expect (shown above). Surrounding the cladding panel are a concrete FE panels and a series of beams. I understand I'm getting the warning because the cladding panel is trying to apply the load to the FE panel and the beam? Consequently I've tried setting a) the beams and b) the concrete panels to 'ignore' with regard to 'trapezoidal and triangular load application but am still seeing this warning - please can you advise? (Note: as far as I can tell there's no geometry issues, e.g. everything is noding correctly and all in the same plane).
Thanks in advance.
I seem to be having a similar problem, however, the provided solutions have not helped. I have even deleted all the claddings, and as soon as I just add one (with or without any load applied), the program gives me the warning.
Please find attached the model.
Ngula
