Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Load distribution
15 REPLIES 15
Message 1 of 16
MUHANNAD.ABU_ABDO
1575 Views, 15 Replies
Load distribution
When i take example from structural analysis book .. and distribute the load from two slab to the beams by using Robot .. there's some thing strange in the lenght of trapezoidal  ..
The pic's will illustrates every thing
Robot Distribution
Muhannad M.Abu Abdo
Structural Design Engineer
Tags (1)
15 REPLIES 15
Message 2 of 16
Robot assumption: lines indicated in red below are generated as angle bisectors.
Rafal Gaweda
Message 3 of 16
So , is this way wrong or right ?
Muhannad M.Abu Abdo
Message 4 of 16
Ask \ search for assumptions adopted for these lines in the book.
I think bisector assumption is more general, physical.
Rafal Gaweda
Message 5 of 16
In R.C.HIBBELER the most common structural analysis book  distribute the load as in the pic .. i'm really confused .. thanks a lot Rafal for your answer and advice
Muhannad M.Abu Abdo
Message 6 of 16
Message 7 of 16
1. This site is blocked I guess in Europe or link is wrong
2. I do not need it. It is for you to understand how it is calculated in book. I told you how it is done in Robot.
Rafal Gaweda
Message 8 of 16
legar
in reply to: Rafal.Gaweda
Assuming that R.C Hibbeler example slab is multi-span slab in X direction and one-span slab in Y direction, then:
1. A-B & C-D linear supports are not fixed
2. A-D & B-C linear supports could be analysed as fixed for continuous load
so R.C Hibbeler solution is better than simple bisector assumption.
In one of Polish Codes was proposed another general assumption:
Message 9 of 16
MUHANNAD.ABU_ABDO
in reply to: legar
which code is this ?? yield line theory
Muhannad M.Abu Abdo
Message 10 of 16
Read carefully post above, look at screen shot - .. in frame.
Rafal Gaweda
Message 11 of 16
legar
in reply to: MUHANNAD.ABU_ABDO
This load distribution was recommended to use in two old Polish Codes (1979) for concrete structures:
BN-79/8812-01 - "Structures with large panel prefabricates. Design and structural analysis"
BN-79/8812-02 - "Structures with cast in situ walls. Design and structural analysis"
Cheers,
Jerzy
Message 12 of 16
MUHANNAD.ABU_ABDO
in reply to: legar
this is too old .. i think if you have any guide according to EC , BS OR ACI ... because i don't trust this theory maybe change in this days or don't approval with ACI ?
Muhannad M.Abu Abdo
Message 13 of 16
Look at this pic .. that's completely confuse .. the length 15 feet .. and it's divide equally 5 feet ?
Muhannad M.Abu Abdo
Message 14 of 16
legar
Muhannad,
Actually if you want exact solution... just use Robot finite elements not claddings load distribution.
I just want to say, that in some situations bisector assumption is to big simplification in load distribution calculations.
Jerzy
Message 15 of 16
MUHANNAD.ABU_ABDO
in reply to: legar
yes i know that .. but i compare the reuslts between Robot and manual calc
Muhannad M.Abu Abdo
Message 16 of 16
legar
Answer:
Simple span slab in both directions and all wall supports the same - so bisector assumption is OK.
Jerzy
