How can i view only the load, with description, for the selected load case only?
For example: when i try to view live loads only, the loads given in dead loads are coming visible.
Solved by Rafal.Gaweda. Go to Solution.
I did that 🙂
It looks to me that the point mass (they are plenty) are applied to all load cases. All of these only point masses only.. Forces are working the it should be.
P.S. I am trying to check the loads from a analysis done by others.
