Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
load description display only for selected load cases
4 REPLIES 4
madhupyboyina
582 Views, 4 Replies
How can i view only the load, with description, for the selected load case only?
For example: when i try to view live loads only, the loads given in dead loads are coming visible.
4 REPLIES 4
Select case for display:
Rafal Gaweda
I did that 🙂
It looks to me that the point mass (they are plenty) are applied to all load cases. All of these only point masses only.. Forces are working the it should be.
P.S. I am trying to check the loads from a analysis done by others.
In case of using Load to Mass Conversion please use Dynamic Mass instead of Global, then calculate model and mass display should not appear in static cases.
Rafal Gaweda
Thanks. That worked.
