Hello!
I created 4 wind load cases and 3 snow load cases. My problem is to create an envelope containing wind cases and another containing snow ones. Is it possible? By doing this I want to reduce the number of combinations generated my Automatic combinations module. My teacher recommended this, too.
I read that robot cant create envelopes. Is it true?
Thanks in advance.
the goal - reduce the number of combinations generated my automatic combinations module?
Take a look at:
Usefull zip in last post on this page;
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Select-Case-Component-No-Results/m-p/3390533
or here
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Editing-load-cases-in-excel-API/td-p/3320573
I was told its theoretically right to make a envelope combination - the Eurocode 1 says that. And the goal of course is reducing the number of combinations. It's a simple steel frame I don't need 200 combinations.
I've read the posts you told me but I see the only way is editing the load cases in excel? Grouping the combinations doesn't make a envelope of them, right? Is there another way?
And if you don't understand me, I want to make a envelope as SAP2000 do it - it has a load combination type - envelope.
I think we do not understand you. Also, at least me, do not know what is envelope case\ combination in SAP.
Envelopes are generated automatically in Robot these ways:
I want to create a envelope of 4 wind load cases and combine this envelope in ULS combinations, for example,
G+Q+0.5*envelope (Wind1; Wind2; Wind3; Wind4).
Thanks for the help. 🙂
And the result of the above is ...?Tell me what you want to get.
Tihs is a combination. I want the maximum values of the internal forces. Instead of combining dead and live loads with 4 wind load cases to be just 1. I hope I gave the right answer.
combine 1
Axial = 100; Moment = 14 (Axial MAX)
combine 2
Axial = 14; Moment = 100 (Moment MAX)
combine 3
Axial = 99; Moment = 99( stress MAX)
thannks for your help ?
but how i can chose combo envelop for design RC ?
Hi @qvt
The design of reinforcement is done for each of the combinations one by one and designed reinforcement is such that it secures element's capacity for all of them.
Please see: Rc Members - Required Reinforcement - Beams
Hola @leidy.arbelaez,
te animo a que si publicas en español abras un nuevo tema en los foros de la Comunidad Autodesk en Español.
Aquí te dejo el link: https://forums.autodesk.com/t5/espanol/ct-p/157
¡Hasta pronto!
¿Te ha parecido útil este post? ¡Deja un like!
¿Tu pregunta ha sido solucionada? Selecciona 'Marcar como solución' y ayuda a las demás a encontrar fácilmente la información.
Your question got successfully answered? Then just click on the 'Mark as solution'
Joaquim Moral
Spanish Community & English - AutoCAD Electrical, Mechanical and Plant 3D products
