Is it possible in Robot to use load bearing sheet as a diaphragm and transfer horisontal wind loads to other columns through it? Pic. attached. Am I in the right place? What plate model suits better for this option: deck-slab, shell, slab-flex and slab rigid diaphragm? Will this option only transfer the loads or I can get the shear stress distribution also (especially in cornesrs)?
Solved by Artur.Kosakowski. Go to Solution.
The picture is missing but you may consider something like this:
Pic. added. Does it matter if I define Orthotropic panel with similar bearing sheet geometry?
Whats the difference between Rigid connection without stiffening and stiffening diaphragm (with second one you have 2 choises: flexible in XY or rigid)?
Does analytical model for transfering loads is more precise? I will try them both anyway.
Thanks for the reply.
The difference will be such that you will have different stiffness of a panel in its X and Y direction. If this is the way the steel sheet behaves in reality then IMHO you should select this option.
For the later the rigid links in the plane of a panel are generated and they resist the in-plane forces. I don't think you want this as you want to " get the shear stress distribution also (especially in corners)".
One thing is still unclear for me: in which cases should i use stiffening diaphragm with rigid or flexible in xy option?
I hardly can think of any practical application of a prior one in a model of a building (structure) but it may be useful for some mechanical modelling e.g. to create a rigid rib inside a wing of a plane at the place it joins a fuselage :-).
For the later it is commonly used for seismic analysis of a multi-story buildings in order to to reduce a size of a model but in such case you most likely switch off mesh generation in its definition.
Thats what I am talking about, if I want to reduce model size or node/element number i do not generate FE mesh in diaphragm. And if this option is useless for structural engineering (at least i have no idea in which case I can use it)... Perhaps mechanical engineers would use it but i think that most of them dont use Robot and uses specific software for calculation. Anyway question answered, thanks. The rest is seems like somekind of offtop )
