Hi!
I'm suddenly experiencing problems when trying to apply loads in the load table. In load cases I have already defined, I want to go to the list column and there type which members to apply the load to. I do this all the time, and suddenly Robot won't let me do this anymore!
I discovered this when I had added a new member, and wanted to add it to an existing acceleration load case. First of all Robot had removed a number of existing members from the load case, apparently at random, and then when I tried to reapply it to the members, I am not allowed to do this.
Maybe I have changed a setting without beeing aware of it?
Regards
Ole K
Solved by Artur.Kosakowski. Go to Solution.
Try the following:
Close all opened dialogs, viewers, tables etc. To avoid any possible interaction with the selection done there
Make sure nothing is selected
Save the file under a new name
Open it and try again
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
