Lines to beams
4 REPLIES 4
tord
757 Views, 4 Replies
Lines to beams
Hi all
Is there anyone who knows if there is a command in RSA that turns an imported line to a beam or column?
As right-clicking on a beam and "copy properties".
Imagine that I import a 3D-drawing from Autocad and just select many lines lines and convert them to be beams of type HEA 200 as an example.
Or could a drawing just be a background and you have to draw out all the beams and columns?
Otherwise, it would be a good improvement.
/ Tord
Tags (2)
4 REPLIES 4
Romanich
in reply to: tord
Just play with settings:
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Mohammed_Ata
in reply to: tord
From any menu , can i open this window ?
Hi
Choose File>> Open. Choose dxf as Type. Press OK, the dialog will open.
tord
in reply to: HoshangMustafa
Thank you
/ Tord
