Discussion Groups
Robot Structural Analysis
Valued Mentor
58 Kudos
LINEAR LOADS
498 Views, 7 Replies
12-26-2011 12:47 AM
Hi. Whenever i have a linear load, be it live, dead or whatever, and I show the loads anyways in the model, the linear loads are revealed even if they do not apply to the part I am showing. Please see figure. Is there a way to stop the linear loads from showing unless it is the part they are applied to.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
Product Support
12 Kudos
Re: LINEAR LOADS
12-26-2011 01:52 AM in reply to: AJA14
Could you send us your model (Compressed RTD file) please ?
Francois Augiere
Support Specialist
Product Support
Valued Mentor
58 Kudos
Re: LINEAR LOADS
12-26-2011 03:13 AM in reply to: Francois.Augiere
Hi. I tried to send a sample model *.rtd, but it says that the extension is unsupported. I also tried to use winrar but I received the same thing. How should I upload it.
Ali Al-Hammoud
Product Support
12 Kudos
Re: LINEAR LOADS
12-26-2011 03:17 AM in reply to: AJA14
Maybe try to rename it first (*.txt instead of *.RTD), then zip it
Francois Augiere
Support Specialist
Product Support
Valued Mentor
58 Kudos
Re: LINEAR LOADS
12-26-2011 03:33 AM in reply to: Francois.Augiere
still doesn't work. it does not recognize *.rar, and even if i change the extension to *.txt it takes it as *.txt.rtd.
Ali Al-Hammoud
Product Support
12 Kudos
Re: LINEAR LOADS
12-27-2011 06:34 AM in reply to: AJA14
Please check the message i sent you in Private Message
Francois Augiere
Support Specialist
Product Support
Valued Mentor
58 Kudos
Re: LINEAR LOADS
12-27-2011 09:05 PM in reply to: Francois.Augiere
I have attached it as you said. Thanks for your assistance. I hope this helps to clarify my question.
Ali Al-Hammoud
Product Support
12 Kudos
Re: LINEAR LOADS
12-28-2011 01:11 AM in reply to: AJA14
This is due to the fact that "linear load 2p" is not a kind of load applied to objects/panels, it is defined by 2 points coordinates. So when you use "Edit in a new window" with panel 9 selected, the linear load 2p is still shown (as part of the same load case).
You could use instead load on edge, with a new definition of the lower slab (see attached modified RTD file, and screen captures)
Francois Augiere
Support Specialist
Product Support
