Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
linear load has not been applied to panel
2 REPLIES 2
pta_simon
990 Views, 2 Replies
I have an error on a model where the message after running the calculation says "linear load has not been applied to a panel".
The only linear loads I have defined are linear 2p loads. Is there an easy way to locate where these loads are on the model?
Tags (4)
2 REPLIES 2
dimogrec
in reply to: pta_simon
I'm not sure if you mean this
pta_simon
in reply to: dimogrec
Thanks for your response.
I believe I have solved the problem. One of the linear 2p loads that was defined was set to zero for all parameters, i.e. size of the load (kN/m), x coordinates, y coordinates, z coordinates etc. This meant it was so small that visually trying to find the location of this load on the screen was not possible.
By doing a structure verification and then clicking on the error to highlight the location of the problem meant it was highlighting a linear load that was 0kN/m and 0m in length.
