Hi
I tried to model Flat Slab and I applied all wall loads as line load cause I cannot use hosted line load because I don't have any beams.
I transferred the model to robot and I found that the meshing did not consider the location of the line load over the slab, how I can fix this problem.
Thanks.
There's no such need.
http://docs.autodesk.com/RSA/2013/ENU/filesROBOT/GUID-5E37DD4E-0242-4C74-BA62-0DE0FA3EE67A.htm
I would recommend that in case you are not sure if a load is applied to a model to follow these simple steps:
1. Create a new load case
2. Define a load you want to check
3. Calculate a model
4. Check if the sum of applied forces is equal to the sum of reactions for this load case
Maybe attachment from message 9 will help you
