I try to test the function of analysis of buckling. Length of buckling in two direction y and z seem not correct. Please help me if I am wrong.
Many thanks.
Solved by Artur.Kosakowski. Go to Solution.
Please check:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Results-Buckling/m-p/3406121
and
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Buckling-Analysis/m-p/3280269
Have you divided the bar as described in the link I inserted in my previous answer?
It mean that Lcrz is buckling length of weak axis with accordant Ncr of column. For the strong axis, need Lcry (more longer) to get this Ncr. Thus, in conclution the Lcrz is the buckling length of clolumn and Lcry is referent length
You need to match the results with the appropriate shapes of buckling.
