Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
LCS of steel member dependent on strong/weak axis?
2 REPLIES 2
TorgrimO
819 Views, 2 Replies
What determines the direction of Y/Z when defining a new profile in section definition? I am trying to define an H-beam with plates welded to the sides with the z axis pointing upwards in the same direction as the original web. When I look at the calc note the lcs is turned around 90 degrees compared to the original coordinate system when I started to draw the cross section.... It seems that it orientates the z-axis to be the weakest axis?
See attachment. The red arrows are the original coordinate system during drawing and the yellow ones is the new lcs after standardisation. I want these to LCS'es to be equal.
2 REPLIES 2
Artur.Kosakowski
in reply to: TorgrimO
Currently the Section Builder module always calculates section properties setting the principal axis in such way that Iy>Iz. The request for option that would allow for decision which axis is Y and which Z (rotating the originally assumed coordinate system by 90 deg) is on the wish list for new versions of Robot.
Artur Kosakowski
TorgrimO
in reply to: Artur.Kosakowski
This was bad news. It makes it harder to work with defined sections and releases...
