Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Layered Wall Sections
3 REPLIES 3
sadornati
470 Views, 3 Replies
I would like to create a model in Robot with multi-layered walls.  Each wall has 3 layers with different properties (outter structural layers and an internal insulation layer).  If I create the cross section of the wall in a "Section Definition Project," how do I export this to the structural model? I found the "Save Section to Database" option, however the section does not show up in the structural model.
3 REPLIES 3
Please check:
http://forums.autodesk.com/t5/robot-structural-analysis/modeling-laminated-glass/m-p/5244419/
http://forums.autodesk.com/t5/robot-structural-analysis/creating-a-composite-panel-glass-unsulado/m-...
Artur Kosakowski
Hi sadornati,
The posts that Artur suggested are the perfect way to model a composite multi layered shell. My personal suggestion is to make an equivalent single layer shell. This will avoid the possibility to have a very complex model to manage. The easiest way is always the best
Good luck
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Thank you.  The simple model was the way to run it.
