I would like to create a model in Robot with multi-layered walls. Each wall has 3 layers with different properties (outter structural layers and an internal insulation layer). If I create the cross section of the wall in a "Section Definition Project," how do I export this to the structural model? I found the "Save Section to Database" option, however the section does not show up in the structural model.
Solved by StefanoPasquini6790. Go to Solution.
Solved by Artur.Kosakowski. Go to Solution.
Please check:
http://forums.autodesk.com/t5/robot-structural-analysis/modeling-laminated-glass/m-p/5244419/
