We have observed in one water tank model we have that the reinforcement calculated in robot that upon varying bar dimensions, large differences in reinforcement result. Attached is a the file and some snapshots of what is occuring. Glad to find the explanation for this.
Rico
Solved by Artur.Kosakowski. Go to Solution.
A min determined by max. allowed bar spacing. Can be switched off in Robot 2015.
Hi Artur,
Thank you for pointing this out. It was very helpful.
@Artur.Kosakowski wrote:A min determined by max. allowed bar spacing. Can be switched off in Robot 2015.
I will advise to get Robot 2015 for this.
Cheers,
Rico
