Hi
Can you please help.
I'm tring to repackage Robot Strucutral Pro 2011x64 to install via a installation script for mass deployment via sccm, over multiple sites.
I can install the application ok but it fails on the language pack:
"Can't create COM Components" then
Error 1722..... (see attachments)
Which transform should it be installed against: RSA-Robot Strucutral Pro 2011x64.mst (the application ) or the RSA.mst
Regards
Rick
Can you run standard installation of RSA on this machine and if any error messages will be reported plase attach the files "Autodesk Robot Structural Analysis Professional 2011*.log" from temp folder of Windows?
