Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Label Manager
5 REPLIES 5
729 Views, 5 Replies
Label Manager
Hi!
Where the robot record the following type of files?
Database profiles
Database loads mobile
Database label Steel/aluminum member type
Thank you for all.
5 REPLIES 5
Rafal.Gaweda
Common
Win XP:
c:\Documents and Settings\All Users\Application Data\Autodesk\Structural\Common Data\2013\
Win Vista:
C:\Users\All Users\Autodesk\Structural\Common Data\2013\
Win 7 32- or 64-bit RSAPro:
C:\ProgramData\Autodesk\Structural\Common Data\2013\
Cfgusr
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
user section databases, material databases, etc.
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Structural\Common Data\2013\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2013\
Rafal Gaweda
Rafal.Gaweda
in reply to: Rafal.Gaweda
labels in this file
"c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\labelusr.rtl"
Rafal Gaweda
t.sautierr
Rafal, instead of defining every labels in robot, is it possible to edit directly the labelusr.rtl in order to build a library (currently I am interested in elastic releases) quickly ?
Actually I ask for this because I haven't manage to find a table for releases that is editable in robot (for example like with support type you can create by a copy paste with excel) ...
thx a a lot.
Rafal.Gaweda
in reply to: t.sautierr
No
API task for you 🙂
Rafal Gaweda
t.sautierr
I think the answer is clear ... 🙂
I'll get back to the forum when it is done.
