Hi!
Where the robot record the following type of files?
Database profiles
Database loads mobile
Database label Steel/aluminum member type
Thank you for all.
Solved by Rafal.Gaweda. Go to Solution.
Common
Win XP:
c:\Documents and Settings\All Users\Application Data\Autodesk\Structural\Common Data\2013\
Win Vista:
C:\Users\All Users\Autodesk\Structural\Common Data\2013\
Win 7 32- or 64-bit RSAPro:
C:\ProgramData\Autodesk\Structural\Common Data\2013\
Cfgusr
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
user section databases, material databases, etc.
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Structural\Common Data\2013\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2013\
labels in this file
"c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\labelusr.rtl"
Rafal, instead of defining every labels in robot, is it possible to edit directly the labelusr.rtl in order to build a library (currently I am interested in elastic releases) quickly ?
Actually I ask for this because I haven't manage to find a table for releases that is editable in robot (for example like with support type you can create by a copy paste with excel) ...
thx a a lot.
No
API task for you 🙂
