Discussion Groups
Robot Structural Analysis
mikibierzo1973
Label Manager
301 Views, 5 Replies
11-05-2012 11:50 PM
Hi!
Where the robot record the following type of files?
Database profiles
Database loads mobile
Database label Steel/aluminum member type
Thank you for all.
Please use plain text.
Product Support
Rafal.Gaweda
Re: Label Manager
11-06-2012 12:09 AM in reply to: mikibierzo1973
Common
Win XP:
c:\Documents and Settings\All Users\Application Data\Autodesk\Structural\Common Data\2013\
Win Vista:
C:\Users\All Users\Autodesk\Structural\Common Data\2013\
Win 7 32- or 64-bit RSAPro:
C:\ProgramData\Autodesk\Structural\Common Data\2013\
Cfgusr
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\
user section databases, material databases, etc.
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Structural\Common Data\2013\
Win Vista:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2013\
Rafal Gaweda
Product Support
Rafal.Gaweda
Re: Label Manager
11-06-2012 12:11 AM in reply to: Rafal.Gaweda
labels in this file
"c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2013\CfgUsr\labelusr.rtl"
Rafal Gaweda
t.sautier
Re: Label Manager
11-14-2013 09:26 AM in reply to: Rafal.Gaweda
Rafal, instead of defining every labels in robot, is it possible to edit directly the labelusr.rtl in order to build a library (currently I am interested in elastic releases) quickly ?
Actually I ask for this because I haven't manage to find a table for releases that is editable in robot (for example like with support type you can create by a copy paste with excel) ...
thx a a lot.
Product Support
Rafal.Gaweda
Re: Label Manager
11-14-2013 11:18 PM in reply to: t.sautier
No
API task for you :-)
Rafal Gaweda
t.sautier
Re: Label Manager
11-15-2013 05:11 AM in reply to: Rafal.Gaweda
I think the answer is clear ... :smileyhappy:
I'll get back to the forum when it is done.
