Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Job Preferences
11 REPLIES 11
Message 1 of 12
stroxy
690 Views, 11 Replies
Job Preferences
Hi, If I modify my job preferences settings, and I want to replace the existing file, do I delete the file and save again under the new name or do I just go ahead and modify the preset "read only" setting and save under the existing name.  Might seem a trivial question, but I have been suffering some crashes and I am not sure whether this is the cause
11 REPLIES 11
Message 2 of 12
Rafal.Gaweda
in reply to: stroxy
Hi
Do you want to assing new job preferences to existing model file or you want to create new model file with new \ different preferences?
Rafal Gaweda
Message 3 of 12
stroxy
in reply to: Rafal.Gaweda
I want to edit job preferences of existing model
Message 4 of 12
Rafal.Gaweda
in reply to: stroxy
So change them.
If you want to store (old) preferrences under specific name use diskette button.
Rafal Gaweda
Message 5 of 12
stroxy
OK thanks,
I just realized I can save my preferences as defaults and that would solve a lot of my problems.
 I kept saving new files and any time i opened in repair mode I would have to recreate the files, sometimes forgetting to change one or two parameters.  If I then went back to the file I created and tried to change these parameters, I got the message the file was read-only.  I know you can right click properties ad disable the read only setting but was not sure what effect that was having behind  the scenes.
In any case I now have me preferred parameters as Default.
Message 6 of 12
Rafal.Gaweda
in reply to: stroxy
I thought you might want to assign correct job prefs to file opened in repair mode.
This is correct way.
Rafal Gaweda
Message 7 of 12
stroxy
OK will do, but are you saying if I save preferences as defaults I lose them if I open in repair mode?
Message 8 of 12
Rafal.Gaweda
in reply to: stroxy
If you save your prefs as a default after opening file in repair mode job prefs in model are removed and defaults ones are loaded.
Rafal Gaweda
Message 9 of 12
stroxy
Which defaults, my saved defaults or "factory" loaded defaults
Message 10 of 12
Rafal.Gaweda
in reply to: stroxy
Rafal Gaweda
Message 11 of 12
massalma
Hi all How can i restore the default prefences of robot , because i made alot of changes in material proporties..... thank you ...
Message 12 of 12
Pawel.Pulak
in reply to: massalma
Users's modifications to material databases in 2015 release are stored in rmat*.xml files in this folder:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2015
where "username" is your login.
In other versions analogously.
It is enough to delete rmat*.xml from this folder. Robot will restore the default then starting.
Pawel Pulak
Technical Account Specialist
