Hi, If I modify my job preferences settings, and I want to replace the existing file, do I delete the file and save again under the new name or do I just go ahead and modify the preset "read only" setting and save under the existing name. Might seem a trivial question, but I have been suffering some crashes and I am not sure whether this is the cause
Solved by Rafal.Gaweda. Go to Solution.
Hi
Do you want to assing new job preferences to existing model file or you want to create new model file with new \ different preferences?
So change them.
If you want to store (old) preferrences under specific name use diskette button.
OK thanks,
I just realized I can save my preferences as defaults and that would solve a lot of my problems.
I kept saving new files and any time i opened in repair mode I would have to recreate the files, sometimes forgetting to change one or two parameters. If I then went back to the file I created and tried to change these parameters, I got the message the file was read-only. I know you can right click properties ad disable the read only setting but was not sure what effect that was having behind the scenes.
In any case I now have me preferred parameters as Default.
I thought you might want to assign correct job prefs to file opened in repair mode.
This is correct way.
OK will do, but are you saying if I save preferences as defaults I lose them if I open in repair mode?
If you save your prefs as a default after opening file in repair mode job prefs in model are removed and defaults ones are loaded.
Hi all How can i restore the default prefences of robot , because i made alot of changes in material proporties..... thank you ...
Users's modifications to material databases in 2015 release are stored in rmat*.xml files in this folder:
C:\Users\username\AppData\Roaming\Autodesk\Structural\Common Data\2015
where "username" is your login.
In other versions analogously.
It is enough to delete rmat*.xml from this folder. Robot will restore the default then starting.
