Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Iterative Modal Analysis
6 REPLIES 6
Dirgs
1338 Views, 6 Replies
Hello!
I'm trying to do a iterative Modal (Pseudo Mode) analysis of a roof steel structure, but I'm getting error nº101 (incorrect data: Improper element number).
I don't understand what's gone wrong or why the element number is relevant for the analysis. I also try between different mass matrix type but it always stuck in same error nº 101...
Can you help please.
Tags (2)
6 REPLIES 6
se2p
in reply to: Dirgs
Do a renumbering begining at 1000 just in case.
Lumped without rotations should be a good choice for a bar made structure. Disable sturm check. See if it helps
Artur.Kosakowski
in reply to: Dirgs
Please attach the rtd file.
Artur Kosakowski
Dirgs
in reply to: Dirgs
I try the renumering of bars, it doesn't work.
Also try the diferent add mass types, global and dynamic, with same result, error nº101...
In attach you can find the model,
Thanks Arthur
Artur.Kosakowski
in reply to: Dirgs
Please set the solver as Auto.
Artur Kosakowski
Dirgs
in reply to: Artur.Kosakowski
A usual direct modal analysis with eigenvalues work fine, for this particular case.
I'm starting to settle the modal analysis type on this substruture to lead to a global spectral analysis much more consuming. For what I understand, for bigger and complex models, obtein natural frequencies with iterative PCG_RITZ method will be the best choice, but I'm stuck in this error...Ii cannot know why.
Artur.Kosakowski
in reply to: Dirgs
The iterative multilevel solver is not compatible with rigid links (error 101). For large models (above 500000 d.o.fs) I would recommend use of the multi-threaded solver with block subspace iteration for 50-100 modes or Lanczos for more modes.
Artur Kosakowski
