Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Isolated nodes and cladding panels
3 REPLIES 3
raried
508 Views, 3 Replies
I have isolated nodes which I have not been able to delete. From what I can work out these appear to be related to the cladding panels.
I don't get a warning at verification, but I do during computation. I've tried to delete $ISONODES and open in repair mode etc, i.e. following other advice on this forum.
Clicking the 'isolated nodes' in the warnings after calculation selects the isolated nodes and displays their list in the node box. However these node numbers don't appear in the node table. They do appear in the node list (object navigation window on left) so I can see thier coordinates. No nodes in that area.
I think the issue may be that I have added a bar across a cladding panel (i.e. after making the cladding panel).
Any suggestions? Thanks again, great to see such an active forum!
Rob
3 REPLIES 3
Rafal.Gaweda
in reply to: raried
File please.
Rafal Gaweda
raried
in reply to: Rafal.Gaweda
Rafal,
I will send you the file but I don't want to share the file by an open link. I'll use our company dropsend account to email it to you.
Rob
Rafal.Gaweda
in reply to: raried
You are on verge of algorithm tolerances checking which bars should be cut by panels \claddings edges because these quadrilateral panel segments are not flat so these cross bracings there are not flat also.
So my advice  - ignore this warning message
Rafal Gaweda
