Hello, I modeled roof trusses with axial loads only. The analysis run but I have two types of warnings:
The first one refers to isolated joints in the model, I can’t see them and then I can’t erase. At the model there are rigid links because the joist are at the same place of trusses joints just above of the top chord of trusses (the top chord of trusses is slope).
The instabilities type 3 appears at nodes of trusses without members in other plan than the truss plan (i.e. node 2073 in direction Ry). Is it necessary making supports in only perpendicular address for these nodes? Or how I can eliminate the instabilities?
The file was send a private message to Artur Kosakowski
Thanks a lot for your help
David Moreno
This is caused by lack of accuracy in defining the geometry of the top part of the roof. The nodes are the calculation ones. In addition you defined overlapped claddings e.g. 2598 and 2599.
This seem to be caused by large difference in stiffness of elements (bars with the same section having 8cm and 671 cm). Mind that you should carefully check the obtained results (if as expected) especially displacements and rotations of nodes.
I will send you the corrected model (top part of roof). Mind that you should redefine loads for this part of the model.
I was eliminate all little beams and I was revise carefully the releases, but instabilities type 3 still appears, maybe it’s due to rigid links and or additional supports a perpendicular plan of trusses.
Thanks for see my model again
The new corrected file was send a private message
David Moreno
David,
I would consider re-defining releases so that one of the bars that 'meet' in the same node is 'fully' attached to it (with no release applied). E.g. for two bars that meet in node 8078 - if you define release on one of them only it is enough to prevent any bending moment generation in this location. Defining releases for two bars you sort of 'detach' the node from them allowing for its 'free' rotation which results in the instability warning.
If I have more the two bars, is it necessary that “only” one releases bending? Or only one holds? For example at node 638 I have a warning instability type 3 in direction RY
Thanks.
In general for bars that 'meet' in one node you should define releases for all but one bar.
In this case the bar 848 is fixed a node 638 in RY local (same global) address, but I have the warning.
The instability of type 3 warning may be triggered by other factors too. Please look at the message 2 in this topic.
