While modeling a structure frame, I started with no axis definition and went on by using copy/move commands. The structure is pretty standard one, so I didn't bothered to create Axis definition prior to modeling.
Now I have a (big) frame structure with me and I want to see the axis information, so that I can have a screenshot of the model with all the axis and grid info.
Is there any way to automatically generate Axis and grid based on columns and floors ??
Solved by Rafal.Gaweda. Go to Solution.
Thats like creating axis manually, right. I have to click each time I want an axis.
I am asking, if there is any way to avoid this.
How such option should work? Please mind that it should be a general one which means columns and walls being 'randomly' located in the model as you are not 'restricted' by the program interface to create only lines of them.
If you have equal spacing among the lines of columns you can indicate the position of the first one and set the number and distance to generate all axes 'automatically'.
There is a way ou can create your axis quickly
Create Nodes in excel xyz, where you want to have an axis (create a 3D - diagonal for example)
Paste all nodes in the Node Table
Be sure all the nodes are visible
Open Structural Axis manager
Click over each node you need for de X tab, for the Y-tab and for the Z-tab
Apply
Select all nodes and delete if you want or you dont need any more
Done!
Yes, thats the manual way to do...But if the structure is huge with sevral floors and inner partitions, this way of doing will take time.
@Rioja : I already have a structure built in the model, so I dont think I have to create separate nodes from the excel...As you said I generated axis by clicking each node.
