Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Is it possible to update/renew profile database?
6 REPLIES 6
Jummybear
844 Views, 6 Replies
I have found that some profiles are miss (for example i use finnish steel section database). However, missed section (for example it is tube 50x50x4) should be in this database and is used quite often. I know that i can add manually sections and save tha database, but its not only that section missed. There are some more. Thats why i ask is it possible to update whole database instead of drawing by hand each missed profile?
6 REPLIES 6
Rafal.Gaweda
in reply to: Jummybear
Yes it is possible.
Open database in Section Database Viewer, in properties unmark "Standard Database...."
then copy whole existing record with similar section to the last line with "*", then update values in cells accordingly
BTW please send us details what is missing + references
Rafal Gaweda
Jummybear
in reply to: Rafal.Gaweda
I will try, thank you for quick reply. What does you mean by "reference"? I dont know what did you (what info, which materials) use to compile finland steel section database. I am from Estonia, but we commonly use all finland steel profiles. Ruukki is one of the biggest factories in Finland, probably the biggest one and we use steel profiles from their catalogue. As i mentioned above, i cant tell at the moment all missed profiles, but for example tube 50x50x4 is missed. They also have 50x50x5, but i suppose it goes as a special order because it is used vary rarely.
Rafal.Gaweda
We made it basing on Ruuki catalog years ago
Rafal Gaweda
For the Z purlin, how i can create a new profile by edit a existing one?
I can not find the profile Z like:
Jummybear
Then i think it will be enough if you team will renew/update profiles from the same Ruukkii catalogue. I hope we will see supplemented database sometime in future with some servicepack/hotfix or whatever. Thanks.
Rafal.Gaweda
You can .
Check this thread
http://forums.autodesk.com/t5/Robot-Structural-Analysis/How-to-create-thin-walled-sections/td-p/3107...
esspecially post 11, attachment EC3.....
Rafal Gaweda
