Discussion Groups
Robot Structural Analysis
Rafacascudo
Is it possible to limit a bar force to a certain value?
309 Views, 12 Replies
07-03-2012 11:59 AM
I want to limit the axial force of a columm or a vertical reaction force to 90tf .I tried using nonlinear supports but it didn´t work. Is there a way to do this?
Please use plain text.
Product Support
Artur.Kosakowski
Re: Is it possible to limit a bar force to a certain value?
07-03-2012 11:52 PM in reply to: Rafacascudo
Either using  a non-linear release or a non-linear support. Mind to set the parameters of the non-linear analysis as shown on the attached picture.
Artur Kosakowski
Rafacascudo
07-04-2012 06:32 AM in reply to: Artur.Kosakowski
Hi Artur
  That´s exactly what I tried to do  except for marking " matrix update after each iteration" . But also doing that I keep getting a zero reaction value where I get 100tf when the UZ direction is fixed
Product Support
Artur.Kosakowski
07-04-2012 06:35 AM in reply to: Rafacascudo
Please send the model and indicate the node number and load case to look at.
Artur Kosakowski
Rafacascudo
07-04-2012 12:24 PM in reply to: Artur.Kosakowski
Artur,
     I solved the problem using Bilinear model with a very high K (10000000)for the 1st spring, zero K for the 2nd spring and a corresponding D1 for the force I wanted to limit.It worked great!
     But now I´m having a weird problem when running the model.I have like 120 combinations and ,it takes like 20secs to solve each one .But after something like 25 combinations ,it starts to not converge. So I stopped the calculations ,deleted most of combinations and only left some that robot reported as non convergent.Ran it again without saving the model and to my surprise they converged also in 20secseach  and without using  " matrix update after each iteration" !!!
Nodes with non linear supports are  10 ,21 ,32 ,33 . Combinations are 41,73,75,89
Model is attached. Rename it to .rar
Product Support
Artur.Kosakowski
07-05-2012 02:37 AM in reply to: Rafacascudo
Try to use the parameters from the attached picture. I have calculated the model and all combinations converge.
Case 132
: 1,35xPP+1,05xSC+0,84xVTsuc+0,84xVT270-1,2xTPgrad
Analysis type:
Nonlin. Combination
Non-linear process: convergent.
Maximum value of process parameter when convergence is obtained
: 1.000
Maximum value of process parameter when convergence is not obtained :
1.000
Artur Kosakowski
Rafacascudo
07-05-2012 07:40 AM in reply to: Artur.Kosakowski
Thx a lot  Artur,
It worked.
  But What I don´t understand is why a combination that doesn´t converge in the first run (without marking "matrix updating after each iteration"), converges if I use calculation restart without modifying anything?
Why the calculation process behaves differently??
The problem is solved, but I´d like to understand that.
thx
Product Support
Artur.Kosakowski
07-05-2012 07:55 AM in reply to: Rafacascudo
I have to admit that I do not fully understand the sequence of actions you made and the idea behind them. Definitely deleting some of the load cases/combinations while the analysis was terminated and then restart of the analysis is not the thing I personally do. The intention of this option was to change the parameters of the analysis when you can see that the process has got little chance to converge with the current settings. I can try to investigate this situation providing you give me the detailed (step by step) description to follow.  As you could see all I did was to use the settings I suggested before :smileywink:
BTW: Have you checked in the calculation report that they actually converged?
Artur Kosakowski
Rafacascudo
07-05-2012 11:54 AM in reply to: Artur.Kosakowski
Artur,
    For just an example to show you ,I limited last load case to be number 41.Combinations 39,40 and 41 don´t converge in the 1st run .After I get the no convergence warning for load case 41 ,I just  click OK and do an analysis restart for just case 41 without changing any settings.The result is completely different and now the combination converges
Watch it in this video.
http://screencast.com/t/jbHGlJc2z
Product Support
Artur.Kosakowski
07-06-2012 02:59 AM in reply to: Rafacascudo
As far as I can see Robot starts to have difficulty to converge the last of many non-linear cases for the BFGS method and the multi-threaded solver (when you restart calculations or delete some of the previous cases then divergent cases will converge). Thank you for pointing this situation out - we will check what exactly happens.
The solution is to either use the Full Newton-Raphson method for the multi-threaded solver (the settings I used) or use the Automatic solver (Sparse_M in this case) for the BFGS method.
Artur Kosakowski
