When I save the out put from the printout composition into RTF file format, it gives a file with inverted tables !!
So, the first column is the last, and the last column is the first and so on.
Please check the images the screen shots !!
Note:
I am using Robot 2015
I am using Office 2013 to open the frt files.
Solved by Rafal.Gaweda. Go to Solution.
