What is the proper and easiest method to analyze two intersecting cables which are fixed on both ends? I have attempted to run "Drawing Model Correction", Compatible Nodes, and Generation of Node at Intersection. Either case, the model will not properly solve. I have already changed to P-delta analysis, removed BFGS corrections and checked Matrix Update after each Iteration box.
My goal is to get load share between the two cables, therefore reactions at all fixed ends. There is to be no constraint at node 7.
For now, i only have a nodal load at node 7 in the z-direction. I will incorporate self-weight and other load factors later. No pretension on these cables.
Thanks in advance.
1. Intersect cables so that you have 4 cable elements
2. Delete case 1 (you cannot have the assembly load case which is assumed as the first defined) with no loads
