Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Internal error that may loss contained in the Robot Model
9 REPLIES 9
Message 1 of 10
706 Views, 9 Replies
We are trying to open the ROBOT model (developed by our other office atbelgiumon same version 2011) but it is showing an internal error that may lead to loss of data contained in the model (refer attachments). If we ignore the error, we get the unreliable results (Please refer attachments). We are not sure about the error.
Same robot model is working fine onbelgiumoffice (i.e. no instability errors nor loss of information warnings…).
Has anyone experienced these problems with screenshots?
Please help...
Thanks & Regards
Deepak Jain
email: jaindeepak2000@gmail.com
Mo.+91-9910205544
Tags (1)
9 REPLIES 9
Message 2 of 10
Rafal.Gaweda
Hi
Try to open this file in repair mode.
Let me know if it helps or not
Rafal Gaweda
Message 3 of 10
in reply to: Rafal.Gaweda
I tried to open the model in Repair mode, but problem is same.
do you want to review the model?
Deepak
Message 4 of 10
Rafal.Gaweda
yes.
I will contact you by e-mail given in your first post
Rafal Gaweda
Message 5 of 10
Rafal.Gaweda
I do not see any problem neither on 32 bit verion nor 64 bit version.
Try:
clear windows %temp% folder
clear robot    cfgusr   folder
restart computer
start robot and load the file to check.
You can not calculate this model on your comp because of error the panels are not meshed
How much RAM memory do you have on this computer ?
Rafal Gaweda
Message 6 of 10
Hello'
Sorry for delay of reply.
Please find the attached screen shot for computer conf.
I will trying to open the model as you adviced and give you update.
Deepak
Message 7 of 10
Rafal.Gaweda
My meshed model needs ~850 MB RAM, so 3 GB should be enough.
Have you tried to update Robot with the latest Service Packs and then check? As far as I can see Sp5 and Sp6 are missing on your version.
Rafal Gaweda
Message 8 of 10
Dear  Rafal Gaweda
Thanks for support,
Now Robot model is working after clear window/temp folder & robot cfgusr folder as you suggested.
again thanks for your help.
Deepak jain
+91-9910205544 (mobile)
Message 9 of 10
stroxy
restart computer
start robot and load the file to check. ....
I saw this in an earler solution.  Is it safe to clear the robot cfgusr folder anytime?
My program keeps hanging or unexpectedly shutting down and I am trying to find the cause/solution!!
Message 10 of 10
Rafal.Gaweda
in reply to: stroxy
Cfgusr folder holds user configuration files.
The files are restored to default ones during robot start if this folder is empty.
Rafal Gaweda
