We are trying to open the ROBOT model (developed by our other office atbelgiumon same version 2011) but it is showing an internal error that may lead to loss of data contained in the model (refer attachments). If we ignore the error, we get the unreliable results (Please refer attachments). We are not sure about the error.
Same robot model is working fine onbelgiumoffice (i.e. no instability errors nor loss of information warnings…).
Has anyone experienced these problems with screenshots?
Please help...
Thanks & Regards
Deepak Jain
email: jaindeepak2000@gmail.com
Mo.+91-9910205544
Solved by jaindeepak2000. Go to Solution.
Hi
Try to open this file in repair mode.
Let me know if it helps or not
I tried to open the model in Repair mode, but problem is same.
do you want to review the model?
Deepak
I do not see any problem neither on 32 bit verion nor 64 bit version.
Try:
clear windows %temp% folder
clear robot cfgusr folder
restart computer
start robot and load the file to check.
You can not calculate this model on your comp because of error the panels are not meshed
How much RAM memory do you have on this computer ?
Hello'
Sorry for delay of reply.
Please find the attached screen shot for computer conf.
I will trying to open the model as you adviced and give you update.
Deepak
My meshed model needs ~850 MB RAM, so 3 GB should be enough.
Have you tried to update Robot with the latest Service Packs and then check? As far as I can see Sp5 and Sp6 are missing on your version.
Dear Rafal Gaweda
Thanks for support,
Now Robot model is working after clear window/temp folder & robot cfgusr folder as you suggested.
again thanks for your help.
Deepak jain
+91-9910205544 (mobile)
restart computer
start robot and load the file to check. ....
I saw this in an earler solution. Is it safe to clear the robot cfgusr folder anytime?
My program keeps hanging or unexpectedly shutting down and I am trying to find the cause/solution!!
Cfgusr folder holds user configuration files.
The files are restored to default ones during robot start if this folder is empty.
