Hello .
Integration with Robot Structural Analysis
(Unknown run-time error)
I wanted try the robot structural analaysis link and it just wont work. I have tried with Revit 2013 to Robot analysis 2013.
Revit 2013 is in building design premium and in subscription but Robot is 30 day trial. Is the problem that one is trial?
What could be the problem?
Solved by kaupo.tennokese. Go to Solution.
The problem is not in revit model . I have tryed with different models but same results . Even with the sampel ones wich come with revit !
Are you using Robot2013 (x32/x64)? I see that the icon in the taskbar looks like the one for Robot 2012.
You have good eye for this cristian.
Revit started to open it in robot 2012.
Now i opened the robot 2013 first and tryed again and all worked fine.
Thank you!
