Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Integration REVIT <-> ROBOT
16 REPLIES 16
Message 1 of 17
pevelor
2223 Views, 16 Replies
Hi
I am trying to get update my revit model from robot. Everything is working just fine, except transfer of reinforcement.
What can I do to fix this problem?
I update from revit as shown below
I use the following settings
And I get the following message
And the following error
Any help on this matter would be much appreciated:-)
In addition, I have not figured out a way to update my robot model from revit. Is this even possible, and if so how is it done?
Regards
Peder
16 REPLIES 16
Message 2 of 17
Rafal.Gaweda
in reply to: pevelor
Please upload robot file
Rafal Gaweda
Message 3 of 17
pevelor
in reply to: Rafal.Gaweda
thanks for looking into it.Smiley Happy
I cant seem to be able to compress the file enough this time, even without results
Please refer to the followin thread which has the same model: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Structure-verification/td-p/3334637 -  Ole Deviks vei 6.zip 246 KB
Message 4 of 17
Rafal.Gaweda
The movie how it works on my side here:
https://www.filemail.com/dl.aspx?id=DFBPROFUIDGSNHH
NOTE: The issues can be related to reinforcement You generated in Robot.
Rafal Gaweda
Message 5 of 17
pevelor
Thanks for the video upload.
The prosess you demonstraded is exactly the same as I have done.
So I reinstalled revit which did not help. But when I uninstalled it and intalled it again it works perfectly.
Thanks againSmiley Happy
Message 6 of 17
pevelor
Hi
I have a follow up question,
Do you have solution for transfer of wall and floor reinforcement from Robot to Revit?
Message 7 of 17
Rafal.Gaweda
Currently it is not possible to transfer plate and walls reinforcement from Robot to Revit.
Rafal Gaweda
Message 8 of 17
Arkamel
I have the exact same problem i have create a structure and now i cant sent what i did on robot to revit..... pleace help me with the solution.
DP. sorry about my terrible english
Message 9 of 17
Arkamel
in reply to: Arkamel
the message that it trows
Message 10 of 17
Rafal.Gaweda
Robot file please.
Rafal Gaweda
Message 11 of 17
alexturbo_
This problem was since 2012 and I can't believe that it's still not available sending slab reinforcement from Robot to Revit, Robot is an amazing software, but I think that it's still not complete till all reinforcement and geometry in slabs and walls can be sent to Revit.
Hope the next version 2015 could enhance this issue.
Message 12 of 17
alexturbo_
Message 13 of 17
stroxy
Hi Rafal
Could you please re-upload this movie.  Also are there any settings that must correspond between the 2 programs for this to work seamlessly?
Message 14 of 17
Rafal.Gaweda
in reply to: stroxy
I am afraid I do not have it anymore
Check attached doc and
http://forums.autodesk.com/t5/robot-structural-analysis/revit-to-robot/td-p/3812616
Rafal Gaweda
Message 15 of 17
hi. @Rafal.Gaweda
Vi deo was deleted. Can you please bring it back? Now is the end of 2019. Is the problem of multi-beam beams when exporting reinforcement from robots to revit already solved?
Message 16 of 17
Hi @ledinhchinh0409
I am afraid not.
Rafal Gaweda
Message 17 of 17
Hi @Rafal.Gaweda
So sad : smileysad:. I do not think it's too hard. Maybe Autodesk does not want to make RSA great. The road to BIM was stopped. I also see you less than before: smileysad:
