Discussion Groups
Robot Structural Analysis
Valued Contributor
pevelor
Integration REVIT <-> ROBOT
779 Views, 11 Replies
02-17-2012 04:13 AM
Hi
I am trying to get update my revit model from robot. Everything is working just fine, except transfer of reinforcement.
What can I do to fix this problem?
I update from revit as shown below
I use the following settings
And I get the following message
And the following error
Any help on this matter would be much appreciated:-)
In addition, I have not figured out a way to update my robot model from revit. Is this even possible, and if so how is it done?
Regards
Peder
Please use plain text.
Product Support
Rafal.Gaweda
Re: Integration REVIT <-> ROBOT
02-17-2012 04:18 AM in reply to: pevelor
Please upload robot file
Rafal Gaweda
Valued Contributor
pevelor
02-17-2012 04:46 AM in reply to: Rafal.Gaweda
thanks for looking into it.:smileyhappy:
I cant seem to be able to compress the file enough this time, even without results
Please refer to the followin thread which has the same model: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Structure-verification/td-p/3334637 -  Ole Deviks vei 6.zip 246 KB
Product Support
Rafal.Gaweda
02-17-2012 06:07 AM in reply to: pevelor
The movie how it works on my side here:
https://www.filemail.com/dl.aspx?id=DFBPROFUIDGSNHH
NOTE: The issues can be related to reinforcement You generated in Robot.
Rafal Gaweda
Valued Contributor
pevelor
02-20-2012 01:25 AM in reply to: Rafal.Gaweda
Thanks for the video upload.
The prosess you demonstraded is exactly the same as I have done.
So I reinstalled revit which did not help. But when I uninstalled it and intalled it again it works perfectly.
Thanks again:smileyhappy:
Valued Contributor
pevelor
02-20-2012 06:43 AM in reply to: pevelor
Hi
I have a follow up question,
Do you have solution for transfer of wall and floor reinforcement from Robot to Revit?
Product Support
Rafal.Gaweda
02-21-2012 03:21 AM in reply to: pevelor
Currently it is not possible to transfer plate and walls reinforcement from Robot to Revit.
Rafal Gaweda
New Member
Arkamel
05-15-2014 10:43 PM in reply to: pevelor
I have the exact same problem i have create a structure and now i cant sent what i did on robot to revit..... pleace help me with the solution.
DP. sorry about my terrible english
New Member
Arkamel
05-15-2014 11:05 PM in reply to: Arkamel
the message that it trows
Product Support
Rafal.Gaweda
05-16-2014 12:13 AM in reply to: Arkamel
Robot file please.
Rafal Gaweda
