Hi
I am trying to get update my revit model from robot. Everything is working just fine, except transfer of reinforcement.
What can I do to fix this problem?
I update from revit as shown below
I use the following settings
And I get the following message
And the following error
Any help on this matter would be much appreciated:-)
In addition, I have not figured out a way to update my robot model from revit. Is this even possible, and if so how is it done?
Regards
Peder
Solved by Rafal.Gaweda. Go to Solution.
thanks for looking into it.
I cant seem to be able to compress the file enough this time, even without results
Please refer to the followin thread which has the same model: http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Structure-verification/td-p/3334637 - Ole Deviks vei 6.zip 246 KB
The movie how it works on my side here:
https://www.filemail.com/dl.aspx?id=DFBPROFUIDGSNHH
NOTE: The issues can be related to reinforcement You generated in Robot.
Thanks for the video upload.
The prosess you demonstraded is exactly the same as I have done.
So I reinstalled revit which did not help. But when I uninstalled it and intalled it again it works perfectly.
Thanks again
Do you have solution for transfer of wall and floor reinforcement from Robot to Revit?
Currently it is not possible to transfer plate and walls reinforcement from Robot to Revit.
I have the exact same problem i have create a structure and now i cant sent what i did on robot to revit..... pleace help me with the solution.
DP. sorry about my terrible english
This problem was since 2012 and I can't believe that it's still not available sending slab reinforcement from Robot to Revit, Robot is an amazing software, but I think that it's still not complete till all reinforcement and geometry in slabs and walls can be sent to Revit.
Hope the next version 2015 could enhance this issue.
Hi Rafal
Could you please re-upload this movie. Also are there any settings that must correspond between the 2 programs for this to work seamlessly?
I am afraid I do not have it anymore
Check attached doc and
http://forums.autodesk.com/t5/robot-structural-analysis/revit-to-robot/td-p/3812616
hi. @Rafal.Gaweda
Vi deo was deleted. Can you please bring it back? Now is the end of 2019. Is the problem of multi-beam beams when exporting reinforcement from robots to revit already solved?
So sad : smileysad:. I do not think it's too hard. Maybe Autodesk does not want to make RSA great. The road to BIM was stopped. I also see you less than before: smileysad:
