Intégration d'un modèle dans revit
Non applicable
1 067 Visites
5 Réponses
Message 1 sur 6
Non applicable
Bonjour,
Je suis étudiant en structure et j'ai finaliser mon modèle de la structure dans RSA. Je veux l'envoyer dans Revit, mais il ne veut pas l'ouvrir. Le logiciel marque que j'ai une erreur de fonctionnement. Pouvez-vous m'aider?
Brondon
0 J'aime
Solutions acceptées (1)
1 068 Visites
5 Réponses
Message 2 sur 6
Artur.Kosakowski
Autodesk Support
Autodesk Support
I can't see any issue with exporting the model from Robot to Revit with the exception of joists which are not supported by the link. I'm attaching the Revit file.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
0 J'aime
Message 3 sur 6
Artur.Kosakowski
Autodesk Support
Autodesk Support
Solution acceptée
To have joists transferred you need to copy joists database from its default location and load joists to RST project before the model transfer as shown on the attached picture.
Artur Kosakowski
0 J'aime
Message 4 sur 6
Non applicable
Thanks Mister to help me as fas as you do. Have a nice days.
0 J'aime
Message 5 sur 6
Non applicable
Hi mister, I change some beams and disposition because my teacher said that my dispositon was wrong. Can you send again or update my model? My computer shutdown when i try to. Thanks a lot.
Brondon Belley-Leduc
Cegep Limoilou Student.
0 J'aime
Message 6 sur 6
Artur.Kosakowski
Autodesk Support
Autodesk Support
Here you are.
Artur Kosakowski
0 J'aime
