Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
installing Robot 2015
18 REPLIES 18
Message 1 of 19
noradeen
1105 Views, 18 Replies
Is 8GB RAM required for installing ARSA 2015? if yes , how can i upgrade 2014 to 2015 and i have only 4GB RAM ?
Best Regards
18 REPLIES 18
Message 2 of 19
Hi noradeen,
I have to suggest you to upgrade your RAM. Try to visit www.crucial.com, there is a scan system that check your PC and find the perfect solution for your RAM upgrade.
Greetings
PasProStudio
www.pasquiniprogetti.eu
Structural + Detailing engineers
Message 3 of 19
Artur.Kosakowski
in reply to: noradeen
The minimum RAM requirements for Robot 2015 is 8GB.
Artur Kosakowski
Message 4 of 19
Rafal.Gaweda
Noradeen
My W7 system after starting eats 3,2 GB RAM itself and no user program is run so 4 GB RAM seems to be a little bit small amount.
Rafal Gaweda
Message 5 of 19
noradeen
in reply to: Rafal.Gaweda
Dear sir
i upgraded my PC RAM to 8GB and when i install i get this message ( attached files)
Best Regards
Message 6 of 19
I did what you said and i upgraded to 8 GB but no result .
Message 7 of 19
Rafal.Gaweda
May I ask you from where you have got , downloaded version 2015?
It is not published yet.
Rafal Gaweda
Message 8 of 19
FilRib
8 Gb of RAM? Tell me that this is a April's Fool Joke........
Message 9 of 19
Rafal.Gaweda
in reply to: FilRib
This is a MINIMUM.
Rafal Gaweda
Message 10 of 19
Rafal.Gaweda
BTW - system requirement is W7 SP1, you have W7 only.
Upgrade your windows system.
Rafal Gaweda
Message 11 of 19
FilRib
So, if i have 4 Gb, will it be possible to install Robot 2015? In Robot 2014 says 8Gb too.... (http://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/CloudH... i'm running it with 4Gb.
Message 12 of 19
Rafal.Gaweda
in reply to: FilRib
Will be possible to install but it is below minimum requirements so we do not guarantee how this will work and such version will be out of ADSK service.
Rafal Gaweda
Message 13 of 19
noradeen
Thanks Mr Rafal
May i know how can i upgrade the OS . ? to be suitable for RSA .
regards
Message 14 of 19
noradeen
Message 15 of 19
Rafal.Gaweda
Rafal Gaweda
Message 16 of 19
noradeen
in reply to: FilRib
Message 17 of 19
Rafal.Gaweda
Rafal Gaweda
Message 18 of 19
Artur.Kosakowski
MInd that for Robot 2015 you have to have SP1 for W7 installed. Only 64-bit OS are supported. XP is not supported.
Artur Kosakowski
Message 19 of 19
noradeen
in reply to: FilRib
Hi Rafal , thanks for your help , RSA 2015 Trail version is now installed Robot2015.png
