Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
1087 Views, 5 Replies
Instability type 3
I've been working through a model and sorting out instabilities and I've reached a point where if I release (pin) any more members I get a type 3 instability somewhere else in the model.  After reading this thread I've made a copy of my model and changed all the members to one section size.  This seems to get rid of my instabilities.  Does this mean I can ignore the type 3 instabilities in my real model?
My model is 95MB so haven't been able to upload it.
5 REPLIES 5
Rafal.Gaweda
in reply to: Rafal.Gaweda
Ok, I've saved the model without results and zipped it and it should be accessible by this link:
https://www.hightail.com/download/OGhjb256Y1MzS29LSk1UQw
Note that currently I am getting a type 3 instability in node 758 direction RZ.  This is because I have changed the releases of bar 3553 to xxxxff. If you moment connect this member then the instability goes away.
I currently have lots of bracing members which are moment connected but need to be pinned members (preferably with a torsional release at one end too).  However if I pin any of them then I get instabilities, but If I change all the section sixes to the same section then the instability goes away.
I would very much appreciate your thoughts on this!
Rafal.Gaweda
mathematical instability - ignore it
if you change all sections onto CHS 406.4x10 instability is not reported
Rafal Gaweda
Thanks for the response.  I thought that was probably the case but how can I tell if it is an error I can ignore or an error which needs to be addressed?
Rafal.Gaweda
