Discussion Groups
Robot Structural Analysis
Valued Contributor
Jorgew09
instability type 3 RX direction
1496 Views, 16 Replies
03-09-2012 05:23 AM
When I calculate my modell i get the following error: instability of type 3 in RX direction
I have looked at the node but everything seems to be correct. I the releases box I have tried to tick off RX, but that did not help.
Please use plain text.
Product Support
Rafal.Gaweda
Re: instability type 3 RX direction
03-09-2012 06:05 AM in reply to: Jorgew09
Open calculatin Report , find there Max min values on stiffeness matrix diagonal and write here these two values.
Rafal Gaweda
Valued Contributor
Jorgew09
03-09-2012 06:31 AM in reply to: Rafal.Gaweda
Min/Max after decomposition:    7,463808e+006         6,847539e+019
precision: 1
Product Support
Rafal.Gaweda
03-09-2012 07:04 AM in reply to: Jorgew09
if the difference between these values is greater than 1e11 \ 1e12 program reports instability number 3.
It is related to big differences in stiffenes of elements for example very short elements exist in model = some inaccuracies.
You can check it this way: on dummy model select everything, make intersection, then open Bars table on View tab. Find shortests bars. Then locate nodes \ places on original model and correct location of nodes.
If it is not the case. Send me model. You already know how.
Rafal Gaweda
Valued Contributor
Jorgew09
03-09-2012 07:15 AM in reply to: Rafal.Gaweda
I don't understand how to do what you told me to do
Valued Contributor
Jorgew09
03-09-2012 07:28 AM in reply to: Jorgew09
I'm sending the file:smileyhappy:
Product Support
Rafal.Gaweda
03-09-2012 07:33 AM in reply to: Jorgew09
Example below
If not - send me the file.
Rafal Gaweda
Product Support
Rafal.Gaweda
03-09-2012 07:54 AM in reply to: Rafal.Gaweda
Inacurracies in your model:
Rafal Gaweda
Valued Contributor
TraitCarré
11-06-2013 03:24 AM in reply to: Rafal.Gaweda
please find attached 2 files.
https://dl.dropboxusercontent.com/u/79282449/AUVENT_V2.zip
the first, AUVENT_V2, is calculated without sismic load and is free of instability.
the second, AUVENT_V2_SISMIQUE, contains sismic loads and shows instability.
Calculation report :
Elém. diagon. de la matrice de rigidité
                Min/Max après décomposition:    4.067231e+002     2.066486e+015
     Précision:    2
Shortest calculaltion element : 0.16 m -> I think it's not too short
- Why?
- How be sure than we can ignore this instability (after checking node displacements, shorts elements)?
- Is it possible to highlight calculation node?
thanks
benoît
Product Support
Rafal.Gaweda
11-06-2013 06:16 AM in reply to: TraitCarré
I do not think so :
Rafal Gaweda
