Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Instability Type 2 in Curtain Wall Model
9 REPLIES 9
Message 1 of 10
1252 Views, 9 Replies
I am trying to analyse an aluminium curtain wall in Robot but I am getting instability type 2 in Ry direction ( and sometimes in Rz direction) at several nodes. I tried to remove the bars connected to these nodes and re-drew them to make sure no separate structure is present but I am still getting the warning message .
Could anyone have a look at the rtd file and shed a light on what might be the cause of this warning message?
Thank you
9 REPLIES 9
Message 2 of 10
Artur.Kosakowski
Try to redefine the releases e.g. like that:
Artur Kosakowski
Message 3 of 10
Thank you for your reply.
I have followed your instructions and applied a rotation release about z axis (Rz ). Now, I am not receiving the warning message but the the horizontal members (transoms) are still showing end moments which is not correct.
Attached is the modified rtd file.
Message 4 of 10
Artur.Kosakowski
I'm sorry my mistake. Please restore your original definition of releases but change the definition of the support.
Artur Kosakowski
Message 5 of 10
I have restored the bar releases to xxxfff and changed the definition of supports as follows:
Top Supports:
Fixed directions: Ux, Uy, Uz & Rz
Mid & Bottom Supports:
Fixed directions: Ux, Uy & Rz
Now, I am getting the following error message: "excessive releases at the bar"
Attached is the rtd file.
Message 6 of 10
Artur.Kosakowski
The default pinned - pinned release definition is:
This is to avoid a bar rotation about its own axis.
Artur Kosakowski
Message 7 of 10
Thanks Artur,
This worked for me but now I have a query:
I have understood why Rx in bar releases should not be released but I could not figure out why Rz should be blocked for roller support (Mid & Btm supports).
Also, I re-did the model from scratch but now, for some reason, planar loads applied on cladding are not being distributed to bars and hence the moment diagram for the frame is not generated.
P.S. We have just upgraded to RSA 2013 so I do not know if this has any effect.
Message 8 of 10
Artur.Kosakowski
To prevent the vertical bars to rotate along their own axes. You may add that to the top support instead if you prefer.
It seems that you accidentally created them as acis objects that are intended for solids. Try the followindg steps:
1. Delete them
2. Open Preferences and mark View Parameters
3. Switch off the default definition in the Solid modeler format
4. Save the file under a new name
5. Restart Robot
6. Open the file and define the claddings again.
Artur Kosakowski
Message 9 of 10
in reply to: Artur.Kosakowski
Thank you for your support and help
Just to clarify
"To prevent the vertical bars to rotate along their own axes "
Does this mean
preventing the vertical bars from rotating about their local axes X (i.e.  about Z in global axes in this case)
Or
preventingthe vertical bars from rotating in ZY plane in glabal axes ?
Message 10 of 10
Artur.Kosakowski
The prior.
Artur Kosakowski
