I am having issues with instabilities within a cranked beam. However, the beam next to it has the same properties and same releases yet there is no instabilty within that beam.
Does anyone have suggestions as to resolve this issue?
Solved by Artur.Kosakowski. Go to Solution.
Try to block RZ rotations in supports and RX rotations at both ends for applied bar releases.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
