Discussion Groups
Robot Structural Analysis
Active Contributor
3 Kudos
Accepted Solution
Instability summary
196 Views, 3 Replies
02-29-2012 06:56 AM
Is there any way of having all instabilities (with node number, type, and direction) being output in a report format? This would make bug hunting in complex models a lot more efficient. If not could this be added to some wishlist?
E
Product Support
326 Kudos
Re: Instability summary
02-29-2012 07:09 AM in reply to: sorgjee
Please check the contents of the text file robwin.log which can be found in the following folder:
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2012\tmp\
Win Vista and Win 7:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\tmp\
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Active Contributor
3 Kudos
02-29-2012 10:02 AM in reply to: pp2008
Beautiful!
Product Support
326 Kudos
06-17-2013 02:59 AM in reply to: sorgjee
Some update to this topic
Starting from 2014 release the summary concerning instabilities is reported after analysis. Moreover clicking displayed message results in automatic selection of all nodes for which appropriate instability was reported.
See the message 2 of this forum post:
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-macro-for-highlighting-nodes-with-instab...
Pawel Pulak
