Is there any way of having all instabilities (with node number, type, and direction) being output in a report format? This would make bug hunting in complex models a lot more efficient. If not could this be added to some wishlist?
E
Solved by Pawel.Pulak. Go to Solution.
Please check the contents of the text file robwin.log which can be found in the following folder:
Win XP:
c:\Documents and Settings\username\Application Data\Autodesk\Autodesk Robot Structural Analysis 2012\tmp\
Win Vista and Win 7:
C:\Users\username\AppData\Roaming\Autodesk\Autodesk Robot Structural Analysis 2012\tmp\
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Some update to this topic
Starting from 2014 release the summary concerning instabilities is reported after analysis. Moreover clicking displayed message results in automatic selection of all nodes for which appropriate instability was reported.
See the message 2 of this forum post:
